Author Topic: Throttle Wiring  (Read 52818 times)
Offline BillysMagicBikeShanty
Throttle Wiring
« on: May 20, 2025, 05:09:30 PM »
Hi, I’m new to this forum.
I’m trying to use the 3-wire throttle (black, red, white) with the Wuxing 29DX 5-wire connector (black, brown, orange, white, green).
Which wires do I splice together?
I’ll attach photos.
Thanks in advance
Re: Throttle Wiring
« Reply #1 on: May 20, 2025, 05:30:15 PM »
Close up photo
Re: Throttle Wiring
« Reply #2 on: May 20, 2025, 07:37:38 PM »
I’ve answered my own question.
3 pin Grin / Cycle Analyst throttle wiring
Red:+5vdc
Black: Ground
White: Speed Control Signal (1-4v output)
5 pin Wuxing throttle wiring
Pin 1: White, 5vdc
Pin 2: Green, Speed Control/Throttle Signal (1-4v output)
Pin 3: Black, Ground
Pin 4: Brown, Lighting Feed
Pin 5: Orange, Battery Voltage Indicator
Operational check good 👍
Horay, now I can use my rear shifter again.
