Author Topic: Do I need a Shunt for a Magic Pie III and Cycle Analyst?  (Read 25214 times)
Offline Jerry
« on: May 20, 2020, 06:09:56 PM »
Hi.   I guess that I'm an unconfirmed member.   I have a really simple question to ask, but I can't find an answer on the existing threads (or on the Golden Motor website).   I simply want to know "Do I need a shunt to use a Cycle Analyst 2.4 display with a Magic Pie III or will it connect directly into the Magic Pie wiring harness without a shunt ?).   I guess the thread title would be something like "Do I need a Shunt for a Magic Pie III and CA ?"     Many Thanks
Re: Do I need a Shunt for a Magic Pie III and Cycle Analyst?
« Reply #1 on: May 20, 2020, 11:49:14 PM »
Hi Jerry, you guessed wrong.  ???
Your account was Confirmed years ago when you originally posted about the sound module, which means you are a "Confirmed" member.  ;)
The shunt will definitely be required as it is the only way that the Cycle Analyst can measure the battery current.
« Last Edit: May 21, 2020, 04:43:22 PM by spellchecker »
