Author Topic: Connectors in Magic Pie 2 Controller  (Read 40947 times)
Offline Just
« on: September 14, 2012, 10:43:49 AM »
Hello All,
What's name of the Connectors on the Front Panel of the Magic Pie 2 Controller? My was damaged so I need its name / part# in order to buy a new one.
Ever could anyone probably a link for the connectors?
Thank you!
Offline MAGICPIE3FOCUSPOWER
Re: Connectors in Magic Pie 2 Controller
« Reply #1 on: September 18, 2012, 08:59:05 AM »
Any pictures?
Offline Just
« Reply #2 on: September 18, 2012, 09:05:25 AM »
Here are the pictures - you could click on them to see them enlarged. Actually I need the "male" part of the connector. Thank you
« Last Edit: September 18, 2012, 09:06:59 AM by dmitryl »
« Reply #3 on: September 18, 2012, 10:01:36 AM »
« Last Edit: September 18, 2012, 10:10:15 AM by MAGICPIE3FOCUSPOWER »
Offline Just
« Reply #4 on: September 18, 2012, 12:05:33 PM »
Yes, this one (see the pictures below):
« Reply #5 on: September 18, 2012, 02:22:40 PM »
It's almost the same as the computer psu connector.
If you want to be cheap look for an used computer atx connector and cut it to fit your controller :)
Offline Just
« Reply #6 on: September 18, 2012, 04:38:14 PM »
No, it's not the same as in the computer, it's just similar...
« Reply #7 on: September 18, 2012, 06:14:16 PM »
Hmm that's too bad!
Offline Just
« Reply #8 on: September 18, 2012, 06:32:35 PM »
Anyway, I need a name of the connector in order to buy a spare one...
« Reply #9 on: September 18, 2012, 06:39:54 PM »
What about 12 pins atx?
Have you measure the dimensions of the connector and compare to normal atx connector dimensions? I mean are the pins and holes sames dimensions?
Offline Just
« Reply #10 on: September 18, 2012, 06:51:50 PM »
yes, it looks like an ATX one...
Offline Just
« Reply #12 on: September 18, 2012, 08:58:09 PM »
Thank you! I'll buy & check!
« Reply #13 on: September 19, 2012, 01:24:19 AM »
I just found this 12 Pin ATX connector set on eBay if it's of any help:
« Reply #14 on: September 19, 2012, 04:09:10 AM »
They look like Molex connectors, and they are available from lots of electronic shops.  No Bets, tho.
