Author Topic: Connectors in Magic Pie 2 Controller  (Read 40596 times)
Offline MAGICPIE3FOCUSPOWER
Re: Connectors in Magic Pie 2 Controller
« Reply #15 on: September 19, 2012, 06:50:35 AM »
Yes but 12 pins atx are rare.
Normal ATX (Molex) are 24 pins......
But like I said before you can use old computer atx 24 pins connector and cut it to the right amount of connectors.
O well 12 pins atx is also cheap ;D
Offline Just
« Reply #16 on: September 19, 2012, 12:20:51 PM »
Thank you Alan! This connector seems exactly I'm looking for!
Could you please provide a link to this item on eBay? Actually there are many 12-pins ATX connector there, but I have not found one as in the picture you attached to your last post. Most 12-pins ATX connector on eBay are for PC and not compatible with GM Controller.
Thank you!
« Reply #17 on: September 19, 2012, 03:45:58 PM »
The link was in the text above the picture, but I'll put it here in full to make it more obvious:
http://www.ebay.com/itm/1x-ATX-PCB-12-P-Pin-90-deg-Angle-Header-Cable-Connector-Plug-Terminal-Wire-Jack-/110950648619
Offline Just
« Reply #18 on: September 19, 2012, 05:13:07 PM »
Thank you!
