Author Topic: I tried my MP III for the first time last night .. but ..  (Read 36067 times)
Offline Terry
« on: July 11, 2012, 07:42:00 AM »
After three days of putting my new e-bike together, the time was come to connect the battery and test the MP3 kit for the very first time. Big disappointment..... After I turned the key on the org. GM battery (48V).. the three LED lights lit up on the thumb- throttle but there was no reaction from the motor itself.
There was no smell or frying sound, just dead.. Very annoying  :(
Are you suppose to program the internal controller first? (I also bought the USB cable)  Or should it work "out of the box"?
/terry
Offline Jemen
Re: I tried my MP III for the first time last night .. but ..
« Reply #1 on: July 11, 2012, 04:46:35 PM »
Hi !
My wheel worked at once. I just loaded the battery and turn the key on and viola. worked well for about 130 kms and stop going. Key switch was broken, I got a new one now. It was bad build in bottom plate. New one is straight.
So now is my flevo back to original battery pack.
Jemen out and b...
« Reply #2 on: July 11, 2012, 05:42:36 PM »
Mine ran out of the box, just not for long.  I'd disconnect the brake connectors from the main cable "Y".  If the brake is on, the motor is off. I fell for it a couple of times.....
Offline Terry
« Reply #3 on: July 11, 2012, 06:52:26 PM »
Hi,,
You solved the problem!! Both bakes was partly on (I haven"t  connected the wires yet). I disconnected the brakes from the main cable, and the wheel is spinning  ;D  ;D. Thks  alot man
/terry
« Last Edit: July 12, 2012, 08:04:08 AM by Terry »
« Reply #4 on: July 11, 2012, 08:32:37 PM »
Hi Terry,
I'm glad to help.  By the way, I blew up two controllers.  They both blew up after I took my Morgen for a drive on a fresh battery charge.  I don't think they liked the 58 volts.....
How do you like the performance?  Isn't it great?
Offline Terry
« Reply #5 on: July 12, 2012, 08:19:11 AM »
Hi Terry,
Damn,, that sounds expensive.. 8)  My new e-bike is not 100% operational yet..I have to install the disk brakes and torque-arm on the front wheel..But it's getting closer  :)
Offline Henry Chang
« Reply #6 on: July 12, 2012, 03:54:33 PM »
I'm not technology department, My idea, If I find the motor kits do not work in Golden,  I do something.
First of all, I am using a multimeter to check the battery voltage,  LED lights lit up on the thumb- throttle ,that should means the battery with voltage. Once again I pull brake handle "1" and "4", try to test again, and if not, I'll change your thumb "3", perhaps  thumb is broken, if not, change a set of signal lines, finally still is no good,  may be a motor is broken, the most likely is the problem of controller.
This is just my observation from the surface phenomenon, is not essential .
Hope everthing is ok.
« Reply #7 on: July 12, 2012, 05:56:34 PM »
Hi Terry,
Hey, you absolutely should get a torque arm installed ASAP.  It is simply amazing how the MP3 can force the drop out open.  While mine is rear drive, other folks have commented about fork fragility, and I think the consensus is that you should fit torque arms to both sides.
TTFN.
PS you're going to want those discs at 25 MPH!
Offline Terry
« Reply #8 on: July 13, 2012, 08:13:50 AM »
Hi Terry,
Yes, torque arm is very important. I bought one from GM Canada..very solid. I am also a bit concern about the front fork. If I would  buy a new kit, I certainly would buy a rear wheel.. However the fork on my bike is 100% steel (not aluminium),, and I guess it's good idea to install torque arms on both sides of the fork in order to reduce stress.
Anyway,, I took it for a spin for the first time last night  :D.. The MP3 is certainly very powerful, just like an e-moped.. I used to have a 250W, 36V with pedelec ,, but this is a new world.
I tried the cruise control also,, very handy  :D  So now I can cruise to work with my e-bike, smoking a e-cigarette or reading news on my kindle ,, he he  ;D
/terry
