Author Topic: Static noise coming from horn  (Read 24486 times)
Offline Phil
« on: May 10, 2012, 06:01:33 AM »
Hi All,
The horn connected to magic controller has started making a loud "static" kind of noise.  Everything is running fine, but the noise is a bit disconcerting. I've tried swapping it for a spare one that I had, but still makes the noise. BTW, I have the 250W mini motor.  Any clues?
Phil
« Last Edit: May 10, 2012, 06:05:01 AM by Phil »
250W 36V Mini Motor
Silverback Mercury2 26" MTB
Magic controler
Ping 36V 10Ah Battery
CA
Land of OZ
Offline Phil
Re: Static noise coming from horn
« Reply #1 on: May 17, 2012, 07:04:51 AM »
Still making the annoying noise, like a radio that's off-station. Think I'll just remove it from the controller.
Phil
250W 36V Mini Motor
Magic controler
CA
Land of OZ
Offline csm
« Reply #2 on: May 18, 2012, 04:02:33 AM »
Hi All,
Phil
Maybe the contacts on your horn switch are dirty and causing a partial connection when not pressed? Try opening up the horn switch assembly(disconnect the battery first) and squirting some non residue contact cleaner in and around it, let the liquid dry, re-assemble and see if that fixed it.
