Author Topic: Increase peddle power?  (Read 33142 times)
Offline fearlessfostick
« on: June 09, 2011, 01:57:52 AM »
My GM 1000 watt moves me along quite nicely.  In fact at full speed I have to be in 18th gear to have any peddle effect.  I like the speed and I like to peddle   Is there a gearing set up that would allow me  to provide significantly more peddle power when riding an ebike at full throttle?  Just curious.
Re: Increase peddle power?
« Reply #1 on: June 09, 2011, 06:30:58 AM »
the DNP Epoch 7 speed freewheel. the last smallest cog has only 11 teeth.
http://store.comcycle-usa.com/Cassettes-and-Chains/Cassettes-24131/5904743-DNP-Epoch-7-Speed/ProductInfo.aspx
Here's some helpful fitting information....  http://goldenmotor.com/SMF/index.php?topic=2788.0
« Reply #2 on: June 09, 2011, 10:15:11 AM »
He is here to learn, and yet he teaches.
Andrew could you stop being so humble!@!@!
« Reply #3 on: June 09, 2011, 10:39:39 AM »
That's what teachers are supposed to do. ;)
Peter, if you can find a 52 tooth chainwheel to go with the above mentioned 11 tooth freewheel, your pedals would rotate one turn every second (60rpm cadence) at 22mph.
The higher gearing should make it possible to pedal assist at higher speeds without having to over rev your legs! ;D
Most non-professional cyclists are comfortable pedalling somewhere between 60–80 rpm (22-30mph with 52:11 gearing).
At 60rpm, I would only manage 14mph with my 42 tooth chainwheel and a 14 tooth rear sprocket. :(
« Last Edit: June 09, 2011, 11:18:54 AM by Bikemad »
« Reply #4 on: June 09, 2011, 11:18:33 AM »
And I commend the good man! ;)
« Reply #5 on: June 09, 2011, 04:27:36 PM »
  ;D I suppose I could be.... 'here to get drunk and irritate' ;D
But it's nice to be able (for once) to answer a members question :D
I have my uses, although they maybe limited!
Also, as Alan says,  a larger front chainwheel also really helps. If you have a four bolt crank arm you may find that a 48Tooth is the largest you can get, it's a nice and easy swap. just undo the bolts, slide through the crank arm to remove and fit the new one. 5 minute job ;)
« Last Edit: June 09, 2011, 04:32:45 PM by Andrew »
Re: Increase pedal power?
« Reply #6 on: June 09, 2011, 04:57:04 PM »
Thanks all for the advice and for not hazing me about misspelling pedal!
« Reply #7 on: June 28, 2011, 02:39:03 AM »
Installed a 52 tooth chain wheel and that by itself is making a difference as I can feel the torque when I pedal .  My top speed level,pedaling (with the wind) has been just over 52kph.  Not bad.  I may look at installing the 11 cog free wheel later.  Imagine how fast I can go when I get in shape LOL. Thanks for all the advice!
