Author Topic: mp front fitment on road bike 700c wheels  (Read 35640 times)
Offline wattsup
« on: April 20, 2011, 08:49:46 PM »
converting a dawes galaxy to lecky on front wheel.. does front fitment of majic pie on fairly skinny forks require torque arms / arms
read twice,write once.
Re: mp front fitment on road bike 700c wheels
« Reply #1 on: April 20, 2011, 09:07:03 PM »
Hey wattsup!
( I like that ) :)
Do you have any pictures of the front forks?
« Reply #2 on: April 21, 2011, 01:08:46 AM »
I found this one, and if they look anything like these:
I would recommend at least one torque arm (but ideally two) should be fitted.
Offline wattsup
« Reply #3 on: April 21, 2011, 06:41:47 AM »
yes this is same bike
Offline wattsup
« Reply #4 on: April 21, 2011, 03:28:49 PM »
here she  is
Offline wattsup
« Reply #5 on: April 21, 2011, 03:37:04 PM »
here she is again, fixed gear/freewheel, dawes galaxy, 16lbs as it is. ordered my kit today 1000w majic pie, gonna make some substantial front fork torque arms, I recon she will fly !!
« Reply #6 on: April 21, 2011, 05:14:32 PM »
Are you filling the middle with batteries?
:D
« Reply #7 on: April 21, 2011, 05:23:08 PM »
that's one skinny green hornet! are you keeping the tyres?
Offline wattsup
« Reply #8 on: April 21, 2011, 05:49:57 PM »
the wheel is still going to be 700c, so yes on tyres. battery is going on a seatpost rack. good thought on batteries, fill  it right up, land speed record here we come :)
« Reply #9 on: April 21, 2011, 11:15:14 PM »
Those seem kinda thin. Im sure they could handle mini motors, but a Magic Pie I don't know. A motor of that weight and power really needs something more beefy like this.
This may be a bit of overkill, but they are strong and wont break. I ran a 48 volt pie in these for about 6 months and they gave a great feeling of confidence.
Offline wattsup
« Reply #10 on: April 22, 2011, 06:42:24 AM »
yes, there is some dought in my mind but as said I will make or have made some good torque arms. they will be in the form of a channel, that wrap around forks around 6 inches long. different forks is an option i,m looking into but they will not be suspension ones. my forks may look weak but they are reynolds steel tubing and surprisingly stiff.
Offline Webby
« Reply #11 on: April 23, 2011, 12:13:28 PM »
You need at least 100mm width between the fork ends and also at least 80mm further up the fork arms so that the pie will fit (although the pie is 60mm thick). Bear in mind that it is likely that your spindle will be at least slightly off centre (not sure if this is to allow for the disk). This might cause you trouble with the thin forks of your's - I think you might be stressing them too much with a Magic Pie albeit steel.
The other thing you might find with static forks is an uncomfortable ride!
Webby
Offline wattsup
« Reply #12 on: April 23, 2011, 03:39:24 PM »
changed my order to rear drive, because of the same thoughts as you.
Offline wattsup
« Reply #13 on: May 24, 2011, 04:49:42 PM »
this is my conversion, nearly ready to go.
Offline wattsup
« Reply #14 on: May 24, 2011, 04:56:10 PM »
another view
