Author Topic: Magic Pie broke...  (Read 66875 times)
Offline Hardcore
Magic Pie broke...
« on: March 11, 2010, 07:52:58 AM »
Hey all,
I'm in a bit of a situation here, in the Netherlands.
My mp doesn't work anymore and I don't know what to do, I was 2 times late in class and all
I know is that it works about 500 meters and then the throttle doesn't work, it works and then it shuts down.
what should I check before sending it all the way back?
Greetings
Re: Magic Pie broke...
« Reply #1 on: March 11, 2010, 11:59:27 AM »
Kevin,
  • What is the battery voltage when the fault occurs? (Are the battery gauge lights still lit up?)
  • Do you get any beeps from the motor?
  • Try holding down the cruise control button (when the fault occurs) to see if the motor runs at half throttle.
  • If you have the pedelec sensor connected, disconnect it and then test the bike again.
  • Make sure that all the connectors are still properly connected and that none of the wires have worked loose.
    (Disconnecting and reconnecting each connector a few times should improve poor contacts)
You should set off earlier to ensure you're not late for class again! ;D
I hope it's something very simple so the motor does not need to be returned.
« Last Edit: June 30, 2017, 06:58:15 PM by Bikemad »
Offline Hardcore
« Reply #2 on: March 11, 2010, 12:58:03 PM »
i don't have a horn inside my mp
the connections I got where all bad and I rea-solderd them
the problem is it works for like 500 meters and then it stops,
could it be that my battery cable is just broke?
« Reply #3 on: March 11, 2010, 02:41:58 PM »
If the battery gauge lights are still working, it means that adequate power is getting to the motor and the battery lead should be OK.
(Unless there is a break somewhere between the moulded junction block on the motor harness and the speed controller within the motor.)
Double check that it's not a sticking brake lever, as that could cause the lever switch to stop the motor from working.
And check for a short somewhere in the brake switch wiring where you have soldered the connections, it might be that the insulation has moved (or worn through on a sharp edge of a soldered joint) causing the wires to touch.
I would check the battery voltage (and the battery gauge lights) when the fault occurs, to rule out any possibility of battery or BMS failure.
Offline Hardcore
« Reply #4 on: March 11, 2010, 02:50:45 PM »
the battery voltage was 54 fully charged so that's okay but I didn't connect the gauge lights.
also I can't test it because it doesn't do anything now.
Offline Hardcore
« Reply #5 on: March 11, 2010, 02:56:16 PM »
the only flaw I found was that the red cable coming from the motor that goes into a connector that goes into the battery, maybe that's it?
should I replace that bit of cable?
Offline Hardcore
« Reply #6 on: March 11, 2010, 03:13:51 PM »
well I reconnected the battery after cutting the ripped part of the cord(wiring) and saw that there also was a peace of at the - side so taped that up with electrical tape. but now I don't know if that was the problem so I am going to school tomorrow early and test it properly :D also the half speed works now if I unplugg the throttle
and I don't use pedelec
« Reply #7 on: March 11, 2010, 03:24:43 PM »
Kevin,
Was it a poor/broken connection or a shorted one?
Either way, let's hope you've cured the problem.
« Last Edit: June 30, 2017, 06:57:20 PM by Bikemad »
Offline Hardcore
« Reply #8 on: March 11, 2010, 03:30:05 PM »
yeah let's hope, this is the 5th problem I got with my mp :o why GOD why
Offline Hardcore
« Reply #9 on: March 11, 2010, 03:56:51 PM »
hey I got another question, my mp doesn't start immediately. I first have to paddle to about 8 km/h before I can use the throttle. I didn't had this last summer?
« Reply #10 on: March 11, 2010, 04:05:43 PM »
If you unplug the throttle, does the half speed work from a standstill?
Offline Hardcore
« Reply #11 on: March 11, 2010, 04:10:55 PM »
no, it doesn't work.
i thought it might be sensorless mode or so?
Re: Magic Pie Problem
« Reply #12 on: March 11, 2010, 04:48:23 PM »
As mine works at half throttle from a standstill with the throttle disconnected, it looks like you could have a problem with the hall sensors (or the speed controller itself).
I would send an email to Tom (zhourenli@goldenmotor.com) explaining the problem and see what he says.
Offline Hardcore
« Reply #13 on: March 11, 2010, 05:24:13 PM »
my connector to the battery broke, this was problem #2 but I had a spare one.
