Author Topic: battery box  (Read 37798 times)
Offline jarocue1
battery box
« on: August 28, 2009, 10:41:50 AM »
First of all say that I'm an amateur at the topic of electric bikes, but every time I investigated more and more passionate on the subject, I have an electric bike with a battery 48v 12 AH-mounted luggage rack but I want to integrate it into The table on the slide drums and want to know where I can find boxes, casings or fittings to install my battery integrated with the controller in the table, someone has done this, please help me.
  Thanks for your time. A greeting
Re: battery box
« Reply #1 on: August 28, 2009, 01:42:28 PM »
Hi  jarocue1,
Some of you question has been lost in translation, but I think you mean something like this:
See Bragu's post here
or this
Offline Gregte
Re: battery box
« Reply #2 on: August 29, 2009, 11:47:13 AM »
In the picture that battery certainly seems to be mounted higher up and further back than it would need to be. Doesn't that make handling rather squirrelly?
Offline jarocue1
Re: battery box
« Reply #3 on: August 31, 2009, 06:56:53 AM »
hi.
Thanks you for your interest, and I wold like if someone built the battery box??... I want to integrate it into the frame of my bike.. any advice?....(sorry for my English, is terrible)... thanks..
Re: battery box
« Reply #4 on: August 31, 2009, 08:50:52 AM »
I have mounted the speed controller in the triangle
of the frame, but even with that thickness I brush
my legs against the wires.  I think that mounting
the battery there would just be too thick.
Just my opinion, tho.
Re: battery box
« Reply #5 on: August 31, 2009, 05:52:26 PM »
hi.
Something like this perhaps?
(Click on image to see what's hiding inside)
I quite like the idea of having the motor in the rear hub and the batteries in the front hub,
giving a lower Centre of Gravity and better weight distribution.
But $3,495 for a bike is just a little outside my price range!
                    36V, 10Ah, Nickel-Metal Hydride (NiMH)
I wonder if GM are planning to develop one of these?
« Last Edit: September 01, 2009, 10:54:10 AM by Bikemad »
Offline jarocue1
Re: battery box
« Reply #6 on: September 01, 2009, 08:41:10 AM »
thanks for your picture, I think the space is limited, between your legs and your triangle, I think good idea incoporate the battery in the triangle because the Centre of Gravity is lower, I like a nice battery box beautifull, in concordance with my triangle and I did not interference when pedaling... Some comes up with an idea?.. thanks
Offline muzza.au
Re: battery box
« Reply #7 on: September 01, 2009, 08:50:57 AM »
Check out the bikes on this website: http://www.stealthelectricbikes.com.au/
I actually plan to do something similar, put my battery in the bike frame triangle and make a frame on which to put a covering of sheet metal similar to the bikes in the pictures. Of course the bike I'm building up is a bit different so it wont look exactly the same.
Muzza.
Offline ccbreder
Re: battery box
« Reply #8 on: September 01, 2009, 04:30:36 PM »
Look at GM slide on battery. also E-BikeKit.com has something.
« Last Edit: September 02, 2009, 10:09:52 AM by Bikemad »
Offline robertozm
Re: battery box
« Reply #9 on: September 03, 2009, 10:09:58 AM »
I am still working on it and actually is not working but it use to have very good "manners"...
http://goldenmotor.com/SMF/index.php?topic=437.0
Offline jarocue1
Re: battery box
« Reply #10 on: September 04, 2009, 08:11:42 AM »
roberto, thaks for  the link, the information has been of is great help, the idea is ti do something similar ...
