Author Topic: Battery level Green wire from throttle control  (Read 31645 times)
« on: July 25, 2009, 02:57:09 PM »
I have both the twist and thumb throttle controller. Both have the green wire that is not conected to a plug. I believe this wire is for battery level indicator but where do I attach it?
Re: Battery level Green wire from throttle control
« Reply #1 on: July 25, 2009, 04:15:06 PM »
Hi Gary
You have to connect the green wire to the +ve wire from the battery for the battery level LEDs to work.
« Reply #2 on: July 25, 2009, 06:17:15 PM »
Thanks Alan, I just tried it and it works great! I figured that was it but didn't want to risk running power into something I was unsure of.
Offline liared
« Reply #3 on: August 05, 2009, 05:20:09 PM »
Alan wrote:
"You have to connect the green wire to the +ve wire from the battery for the battery level LEDs to work."
What is the "+ve" wire?
The big red plus wire coming out from the battery or something within the controller?
Bengt
Offline wayne3109
« Reply #4 on: August 05, 2009, 08:57:37 PM »
I'd say '+ve' means positive... ;-)
« Reply #5 on: August 05, 2009, 09:34:43 PM »
"+ve" = positive = +      "-ve" = negative = -
Yes, the big red power output wire from the battery will be fine.
If you have a separate power switch on the bike, make sure you connect it on the speed controller side of the switch, or your battery meter lights will be on all the time.
