Author Topic: What is maximum charge rate for LiMn battery?  (Read 28968 times)
Offline Gregte
« on: July 03, 2009, 03:30:44 AM »
I recently bought a LiMn 36v 16Ah battery from Golden Motor and it came with a 1.8 amp charger. My question is, what would be the maximum safe charge rate (amps) and voltage that this battery can be charged at?
I  have looked all over the web for an answer and cannot find anything that is very definite or clear. TIA
Offline TOM
Re: What is maximum charge rate for LiMn battery?
« Reply #1 on: July 03, 2009, 03:50:51 AM »
36V/4A charger
42V
Offline Gregte
« Reply #2 on: July 03, 2009, 04:08:18 AM »
Thanks Tom. I think what I might do is connect the output of two chargers I have (both are 2 amp chargers for 36v lithium batteries) in parallel to provide 4 amps of charging current. This should charge my battery twice as fast.
« Last Edit: July 03, 2009, 04:10:20 AM by Gregte »
Offline GoldenMotor
  • GoldenMotor
  • Emperor
  • Dark Templar
    • GoldenMotor Youtube
« Reply #3 on: July 03, 2009, 04:45:08 AM »
The higher the charge rate, the lower the battery lifespan. There is no maximum charge rate.
Offline Gregte
« Reply #4 on: July 03, 2009, 05:17:02 AM »
Thanks Yao. I think I will rethink my plan and just stick with the 2 amp charger.
