Author Topic: 36 volt, 600 watt Hub Motor change for 48V/50A controller  (Read 31926 times)
Offline Mbra
I have Wilderness Energy Brushless 36 volt, 600 watt Hub Motor I want to know if I can change for the new
  48V/50A Cruise Speed Controller  thank you.
« Last Edit: June 30, 2009, 01:19:10 PM by mbra »
Re: 36 volt, 600 watt Hub Motor change for 48V/50A controller
« Reply #1 on: July 01, 2009, 10:15:02 PM »
You would have to contact Wilderness Energy to get the
actual max wattage for that motor.
I suspect that you risk burning out the motor by putting the
higher voltage controller on it.
Wattage is (basically) voltage times Amperage.
600W/36V is just under 17Amps continuous.
The 48V controller is 1000W, (About 20Amps continuous)
