Author Topic: My new regenerative controller  (Read 26932 times)
Offline David Merrill
« on: June 19, 2009, 03:08:15 AM »
My new regenerative controller seems stuck in economy mode. It is only about 3/4 the power of my last controller, which is now broken so I cannot use it to test the motor.
I am wondering how to raise the current on the regenerative controllers? I thought a programming module would come with it but may have misread that part.
Regards,
David Merrill.
Re: My new regenerative controller
« Reply #1 on: June 21, 2009, 02:49:12 AM »
The new BAC controllers are not Regen, but the older
regen controllers do not have an 'economy mode'
My guess is that you have a failed hall effect sensor
on the motor, and that is keeping the controller from
being able to sense the speed of the wheel, so it is
in the 'failure' mode where it can drive the wheel without
any feedback.
Double check your wiring, make sure the hall effect
sensor pins did not push out or bend over in the connector.
