Author Topic: How to adjust the engine inertia, controller EZkontrol A48500 and 5 kW motor  (Read 42084 times)
Offline Bublifuk21
Hallo everyone. I would like to ask you. I am working on new project with EZkontrol A48500 and 5 kW motor. Everything work fine, except one problem. The motor has very long enertia or run-down, (don't know if I translate it correctly). In other words, when I have the gas turned on, and I turn it off, the motor is spinning very long time, till it stop. It is problem for me, because it is connected on gearbox and my machine go further couple seconds. I think, that in app for EZkontrol A48500, should be parameter, which could change this behavior. I know, that probably it is not possible to set it directly, that motor will run exactly and react immediately, when I let of the gas, but at least to short that time, when the motor will spin after gas turn off.
I know, there is a brake, which I can use, but for me it is last option, because it is operation moreover.
Thank you very much for all comments.
