Author Topic: Improve acceleration on EZKontrol 48V BLDC and 5kW Motor  (Read 49321 times)
Offline Silverfixer
« on: June 22, 2025, 09:39:08 PM »
I purchased the items listed below (plus contactor and cooling system) for an electric conversion of an off road go kart buggy. I have these setup with two 48v liFePo4 batteries, each battery is 32AH and vendor specifies that a single battery can output 200A for 10s and 120A continuously. The go karts top speed is great at about 27 mph but the acceleration is slower than I'd hoped. It seems to take quite a while for the controller to increase the amperage up to the maximum 250A setting limit. Even in sport throttle mode, it doesn't seem to increase the acceleration amperage up to 250a for quite a while.
Are there other controller settings I can adjust to increase the acceleration?
Thank you
EZkontrol 48 Volt Universal BLDC Motor Controller 500 Amps (3-5 KW)
5 KW BLDC Motor Air Cooled 48 Volts
Re: Improve acceleration on EZKontrol 48V BLDC and 5kW Motor
« Reply #1 on: July 03, 2025, 05:30:57 PM »
Hi SilverFixer
There are eight different versions of this controller.
The model number starts with a letter followed by 6 or 7 digits.
Please let us know which one you have.
Elmer.
