Author Topic: SHORT SPOKES KIT  (Read 47173 times)
Offline Todd75
SHORT SPOKES KIT
« on: July 05, 2024, 05:33:06 PM »
...HELLO......Has anyone here replaced the spokes on a Magic Pie 5 26" rim....or any other rim with SHORT spokes? I'm looking for a re-spoke kit for this rim/motor that has spokes made out of stronger (thicker?) material. Can anyone steer me in the right direction? Any input appreciated.
Re: SHORT SPOKES KIT
« Reply #1 on: July 06, 2024, 12:36:49 AM »
The standard spoke length for the 26" MP5 is 110mm, the same as MPII, MPIII and MP4:
I would use Sapim 13/14g stainless steel single butted strong spokes with 14g nipples, which Sapim recommend for eBikes and tandems:
These butted spokes are very strong (1250N/mm2) and rated for 1.6 million revolutions.
Gary made a good video showing how to re-spoke a Magic Pie wheel which may be helpful.
However, I strongly recommend that the spokes are fitted with their heads on the inside of the flanges as shown below:
This provides much better support for the spoke elbows which greatly reduces the chance of breakage due to fatigue and also improves the lateral strength of the wheel.
Check out this post to see how to calculate the correct spoke length if you are fitting a different depth rim.
« Last Edit: July 06, 2024, 12:50:58 AM by Bikemad »
Offline Todd75
« Reply #2 on: July 06, 2024, 05:37:04 AM »
......Thanks so much....I couldn't ask for a better response. Could I ask you....Who sells this kit? Is there a preferred seller out there?
