Author Topic: What connector is this?  (Read 44345 times)
Offline Cosmitz
« on: June 22, 2024, 02:23:10 PM »
This is a relatively quick one, i'm working on connecting to a new TCMAX using the VEC300/HC3X controller and I found most of all the information I need EXCEPT what plug is that. From initial pictures I thought it was a 6pin atx-style plug but it's much smaller. Pic related.
Re: What connector is this?
« Reply #1 on: June 22, 2024, 03:30:26 PM »
Hi Cosmitz andto the forum.
After studying the picture it looks as if the required plug might be a Molex Micro-fit 3.0 connector Pt. No: 43025-0600.
Check out the pdf drawing to see if the dimensions match your controller's connector.
Offline Cosmitz
« Reply #2 on: June 22, 2024, 04:09:43 PM »
Thank you, that's exactly it. I happened upon a 8pin microfit connector in a dell workstation at work right now as I was losing my mind and it looked the right size, sadly the keying is not compatibile with 6 pin even if I chop 2 pins off. At least it's been confirmed as to what's needed, now just need to find a matching connector on the local market and I can finally get this rolling and activate regenerative  breaking on my TC Max. This has all been more learning than I signed up for to save 30 bucks. :)
