Author Topic: EZ Kontrol Single Axis Throttle configuration  (Read 48120 times)
Offline Bangelor
« on: April 26, 2024, 10:50:56 AM »
Hi everyone,
I am trying to build a throttle for an electric boat motor. I want to use the following Hall Sensor for the throttle:
VISHAY
981HE0B4WA1F16
It provides a 0.5-4.5V analog signal.
Is there a way to configure the EZ Kontrol Controller (A48 500) in away so that 2.5-4.5V is forward and 2.5-0.5V is reverse?
If this is not possible, how can I make the controller change rotation direction when the throttle is pulled to reverse?
Thanks and have a nice weekend!
Re: EZ Kontrol Single Axis Throttle configuration
« Reply #1 on: April 27, 2024, 12:03:00 AM »
With the VEC500 controllers you have to set the Throttle mode selection setting to Hyperbola using the USB programming cable and software for the controller to work with a boat style throttle, but as I have no experience with the EZ-Kontrol controllers, I don't know what programming options are available from within the EZ-Tune Android App.
Apparently, "There are hundreds of programmable control parameters for you to play around and fine tune your drive system to satisfy your expectations!" However, if you can't find the required setting for a boat style throttle you may have to contact your supplying dealer and ask them.
