Author Topic: Dual Magic Pie Edge with cycle analyst 3.1 - wiring the throttle  (Read 38114 times)
« on: September 25, 2021, 10:16:33 AM »
hi, gratis plenum !
i am making a trailor, for trike, with 2 pcs golden motor mp edge motors, 48 v 22 a
i also have grin tech cycle analyst 3.1
and I have gring tech double shunt
i need to connect all those together
is the attached pdf scheme correct ?
i think I only need to connect green wire (throttle) from grin dual shunt, to each motor green (throttle) wire - ja ?
connecting black wire from double shunt is not needed ?
thank you for your help
aum
s love nia
Hi Aum andto the forum.
I had to start another topic as your original post could not be viewed.
Try attaching the pdf to a reply to this post and let's hope it is visible.
