Author Topic: Settings wanted for Magic Pie Edge  (Read 39776 times)
Offline Old Man Terra
« on: August 11, 2021, 11:56:02 PM »
Was member for years and just changed name. Was Old Man Tomahawk. My post: Does anyone have controller settings for Magic Pie Edge/48V10AH/BAC-601-v5/Thumb Throttle/PAS. I want maximum range and top speed of 15-18MPH, not looking for a sports car but slow and steady for a LONG way. Thanks
Re: Settings wanted for Magic Pie Edge
« Reply #1 on: August 12, 2021, 10:32:48 PM »
Hi Tom and welcome back.
To extend the range you will need to reduce the Battery drawn current setting to prevent the motor from drawing so much power.
The less power you draw from the battery, the greater your range will be.
To limit the maximum speed you will need to reduce the Maximum Forward speed (rpm) setting until it can't exceed your preferred maximum speed at full throttle.
If you wish to rename your old user account (OldManTomahawk) you should be able to do that from the Account Settings link under the Modify Profile section.
However, if you cannot access it because you've forgotten your password, please let me know and I can email you a temporary password so you can login to your old account and reset the password.
