Author Topic: Is this safe for Lifepo batteries???????  (Read 30947 times)
Offline SherylinRM
« on: October 01, 2020, 03:41:44 PM »
I will [hopefully] be getting my 280Ah lifepo batteries this week.
However the special charger and BMS won't come for a while yet.
Is it safe to use my 8Amp 24 volt Gel lead acid charger on my Lifepo batteries until the proper charger and BMS comes?
Yes I know it will be 35 hours if I have to charge it from a full discharge.
However I will not be charging them fully, nor discharging them fully either.
Just that I need to use my mobility scooter and the lead acid batteries in them now are not going very far as it gets colder.
I read a book that has "Don't Panic" on the cover ;) LOL
Re: Is this safe for Lifepo batteries???????
« Reply #1 on: October 02, 2020, 12:19:56 PM »
Yes, it should be OK to charge your new LiFePO4battery with your existing charger as long as the charger does not get too hot and you don't allow the charging voltage to exceed 28.6~29.2V.
Offline SherylinRM
« Reply #2 on: October 02, 2020, 01:25:03 PM »
I thought as much.
Was just wondering if there were any hidden "gotchas" mostly.
Ok thanks again Alan :)
