Author Topic: 48V BLDC 1.5kW Direction Change  (Read 26780 times)
Offline Davistomm
« on: September 07, 2020, 05:05:23 PM »
Hey y'all-
Tom here from Denver. Got the idea to convert a 1977 Honda Z50 to a little EV after picking it up in boxes off Craigslist. Been reading a few threads on folks wanting to reverse the motor direction of the BLDC motors, but I haven't had any luck after working through the steps outlined in the thread.
https://goldenmotor.com/SMF/index.php?topic=6071.0
Engine- BLDC 108/4S 1.5kW from Golden
Controller- MX30AV3.0 that came with the kit
I've moved everything back to proper wiring after trying the various combos so it's turning clockwise if you're looking into the spindle, however I need it to run counter clockwise for my needs on this little scooter.
Any help is greatly appreciated!
Offline Davistomm
Re: 48V BLDC 1.5kW Direction Change
« Reply #1 on: September 07, 2020, 05:13:36 PM »
Not sure if I should delete the original post but found this resource and it solved my needs in case anyone else is in the same boat:
http://www.uumotor.com/f/how-to-change-a-bldc-motor-rotation-207.html
