Author Topic: Which forward/reverse switch do I need for my 2 golden Motor 3KW  (Read 28023 times)
Offline Philippe
« on: September 04, 2020, 12:43:48 PM »
I have acquired two 3KW  motors and controllers  from this company as well as a speed control pedal. These will work on a single UTV. I believe that I will need a  current inverter to provide for forward/reverse control. Which of the Golden Motor products should I purchase? Thanks.
Re: Which forward/reverse switch do I need for my 2 golden Motor 3KW
« Reply #1 on: September 04, 2020, 05:29:40 PM »
Hi Philippe,
All you need is a simple switch to ground the reverse wire to select reverse:
There is minimal current being switched so most switches (big or little) can be used.
Offline Philippe
« Reply #2 on: September 04, 2020, 06:24:35 PM »
Do you mean  to ground the brown forward/reverse  wire on the diagram above?
« Reply #3 on: September 04, 2020, 07:34:45 PM »
Yes, you just need to connect a switch to the "forward/reverse" wires as shown below:
When the switch contacts are open, the motors will run in the default direction of rotation, but when the Brown wire is switched to ground (Black wires in diagram are ground), they will run in reverse.
You will obviously need to connect both Brown wires (one from each controller) to the same switch contact to reverse both motors simultaneously. ;)
Offline Philippe
« Reply #4 on: September 04, 2020, 07:42:36 PM »
Thanks this is very helpful :D
