Author Topic: Getting it to run...  (Read 23687 times)
Offline redbaron
« on: April 17, 2009, 05:12:11 PM »
I just received my 48V1000W GM setup. I installed the wheel and rigged all the components up on the bench to test the unit. Batteries are loaded and connected. Breaks, throttle, horn/reverse, motor, hall, all connected. Turn the throttle. Nothing.
Now troubleshooting starts. But where. I have a PAS (pedelec) sensor in my box but I did not connect it. COuld that be it?
Or is there a sequence of initial push/pull/hold, double push or whatever that you need to do to initiate the controller?
Or is it locked because of an alarm?
how to diagnose? I have seen the flowchart and the the most recent FAQ but they are silent to this issue...
Dirk
Offline TOM
Re: Getting it to run...
« Reply #1 on: April 18, 2009, 12:20:01 AM »
You could read our schematics drawing,especially 3D,it will help you.
Or you could take a photo with your wire how to connect?
Email to:  zhourenli@goldenmotor.com
« Reply #2 on: April 27, 2009, 12:31:47 AM »
Dirk;
Can you snap a pic of how you hooked up your wires and post them here?
Close up of the speed controller connections will help alot.
