Author Topic: New member seeking advice  (Read 23513 times)
Offline Manassasralph
« on: July 05, 2020, 11:51:19 AM »
I am a new ebike rider, and have just purchased a used ebike with Magic Pie 5 (VECTOR) 26 Inch Rear Conversion Kit, installed.
After going over the bike (cleaning), I have found two coax wires cut.  One is on the front forks (has a speed sensor, still on the front forks), the other is on the back frame, opposite side from the chain.  No digital display came with the bike (I suspect the two wires went into it).
Where can I find out what's missing from my setup?
Re: New member seeking advice
« Reply #1 on: July 05, 2020, 03:02:56 PM »
Hi Ralph andto the forum.
The cut off wires are probably from the original bike prior to the fitment of the Magic Pie, as the Magic Pie doesn't use Coax cables.
If you have the original make and model details you may be able to trace the missing components, but I doubt they will be compatible with the Magic Pie and this is probably why they were removed in the first place.  ;)
