Author Topic: HPM05KW - 48V, 5kW BLDC Motor  (Read 30700 times)
Offline Mohan
« on: June 09, 2020, 08:49:04 AM »
Dear Team,
Recently we had bought a 48V, 5kW BLDC Motor from Golden Motor. And currently we are trying to run the motor with external inverter set up.
We had rotated the motor manually and obtained the hall sensor feedback (1k pull up to 5V is used externally in hall sensor feedback)
We are trying to run the motor with below switching table.
Deg   A   B   C   UP   UN   VP   VN   WP   WN
00     0   1   0    1      0     0     1     0      0
15     0   1   1    1      0     0     0     0      1
30     0   0   1    0      0     1     0     0      1
45     1   0   1    0      1     1     0     0      0
60     1   0   0    0      1     0     0     1      0
75     1   1   0    0      0     0     1     1      0
90     0   1   0    1      0     0     1     0      0
Kindly note it is four pole motor.
Here U phase is Yellow cable, V phase is Green cable, W phase is Blue cable.
Could you please confirm if this switching pattern is okay?
Regards,
Mohana Krishnan M
Edit: Table misalignment corrected.
« Last Edit: June 09, 2020, 09:24:34 AM by Bikemad »
