Author Topic: MP5 rolling resistance  (Read 29134 times)
Offline Bentbike guy
« on: August 21, 2019, 05:18:31 PM »
Recently got my tadpole trike running w/ a MP5 rear hub drive running 36v (programed for 36v)
My issue is amount of rolling resistance going forward or backwards by just pushing trike.
forward is not real bad but pushing trike out of garage going backwards there seems to be alot of rolling resistance.
Started out w/ fully charged 36v battery and rode about 2 miles on level paved streets and battery shows about 1/3 of charge is used. Most I have gone on fully charged battery, level paved road is 8 miles before it won't go anymore.
Maybe a bad motor?. checked all my frame to hub clearances w/ no issues.
am searching for washer placement. I only used washers on outside of dropouts.
This is my first hub drive and thinking I should have gone w/ mid drive instead. Have a second trike w/ mid drive and it just runs great.
Re: MP5 rolling resistance
« Reply #1 on: August 21, 2019, 11:02:02 PM »
The axle washers must be fitted on either side of the frame dropouts to prevent the axle from damaging the frame as shown below:
The only physical connection between the axle and the rotating wheel is the two wheel bearings, and I have not yet come across a seized bearing on a new motor.
If your rolling resistance is greater when pushing the trike backwards, it could be that the freewheel's gear cluster is binding against the frame because the innermost axle spacer washers have not been fitted.
The freewheel should rotate easily when you pedal backwards with the wheel stationary, if the freewheel is jammed against the frame, then it will probably refuse to move when pedalling backwards, forcing the chain to pull against the spring loaded derailleur mechanism making the chain sag along the top run between the freewheel and the chainwheel.
However, if the binding is not due to the freewheel touching the frame, then it could be due to an alignment problem with the rear brake mechanism.
The only drag that should exist is the magnetic forces acting between the rotating motor ring and the fixed stator on the axle, therefore the wheel should rotate relatively easily when pushing with just one finger against the outer diameter of the tyre with the wheel raised off the ground.  ;)
If the freewheel or the brakes are binding badly, it might account for your unusually low range (8 miles) with a fully charged battery on level roads.
