Author Topic: VEC-500  (Read 60886 times)
Offline Jory
VEC-500
« on: July 23, 2019, 05:14:26 PM »
I recently acquired an 800 lb. eco-car and have installed a VEC-500  72 volt controller and 10KW BLDC motor.  I am using 4 sixty volt  Pacifica 2.4KWH batteries in parrallel.   The car goes 42 MPH and has a power at full throttle of 6KW.   I did not change the configuration of the controller yet, but left it just as it came in the box.    Since I want the motor to use its 10 KW power capacity, what is my next step?   Shall I use the USB connector and reconfigure the controller?  If so, what should I set the parameters to?  The batteries I am using are pouch batteries for the Pacifica Hybrid.   (I have lots to sell, by the way)   I can easily rebuild those batteries to be three 80 volt batteries in parallel  Would that give me the power I need?   Jory Squibb, Camden, Maine.
Re: VEC-500
« Reply #1 on: July 24, 2019, 01:07:26 PM »
I have already posted a reply to your other post.
