Author Topic: How to program the Black Pie 5 with this battery  (Read 25991 times)
Re: How to program the Black Pie 5 with this battery
« Reply #1 on: June 19, 2019, 11:03:32 PM »
If the controller is already set for 48V operation, it will work fine with that battery on the default settings.
However, if you need to change the voltage setting from 24V or 36V to 48V, you will need either the USB Programming cable and a PC with the programming software or the Bluetooth dongle and a compatible smartphone with the Bluetooth programming App.
