Author Topic: Magic Pie V3 - Regenerative Braking Setup  (Read 27153 times)
Offline GenK_777
« on: June 11, 2019, 01:06:50 AM »
Hi All,
I have a Magic Pie Version 3, 1000W Direct drive hub motor (48VDC). The question have is how do I setup the regenerative braking ability on this motor? Do I need a cycle analyst or is there some other way to do it? Thank you for your help with my question.
Offline Pwd
Re: Magic Pie V3 - Regenerative Braking Setup
« Reply #1 on: June 17, 2019, 06:50:48 PM »
Hello,
you don't need a cycle analyst to setup regen braking. You will need a USB programming cable designed for your Magic Pie 3 and the Golden Motor programming software which can be found here:
https://www.goldenmotor.ca/pages/Downloads.html
