Author Topic: I can't find out the correct parameters for the VEC200 Controller  (Read 22969 times)
Offline Dve46
Hello Goldenmotor.com Forum,
I recently bought a HPM3000 BLDC motor and a VEC200 controller with 48V. I downloaded the software (version 3.30) and successfully connected it to the controller. Some values were already there but the voltage was wrong for example. So I assume that the values are not right for my motor. I would appreciate if you could help my out a little bit, because I googled a lot and just couldn't really find anything. And is there a way to find out the maximum current of my battery? I also hope I got the posting thing here right ;)
Thanks in advance! ;D
