Author Topic: Waterproof case for VEC Controller  (Read 51643 times)
Offline Pedrotorres
« on: February 15, 2019, 02:43:22 PM »
Hello all,
My setup is a HPM3000 48V motor and a VEC240 controller. My application to use it on a boat as an outboard. On this, I am assuming that this controller is not waterproof and I wonder wether is possible to enclose this controller in a sealed waterproof box without consider any overheat effects. Any thoughs on the ventilation requirements (considering the huge heatsink this controller has)?
Re: Waterproof case for VEC Controller
« Reply #1 on: February 15, 2019, 08:54:54 PM »
Hi Pedro andto the forum.
As the controller's heatsink is responsible for the majority of the controller's cooling, a water cooled heat sink plate could be installed inside the waterproof box to ensure that the controller is sufficiently cooled inside the sealed box:
Click for more details.
Using an aluminium box would also help to dissipate any additional heat that was not directly absorbed by the cooling plate.
« Last Edit: October 08, 2020, 10:50:33 PM by Bikemad »
Offline Pedrotorres
« Reply #2 on: February 18, 2019, 04:39:46 PM »
Thank you Alan for the response :)
