Author Topic: Linear Regen  (Read 23198 times)
Offline Mikebf
Linear Regen
« on: January 10, 2019, 06:04:52 PM »
New member, converting my trials bike to electric. Really cool to see a number of other doing the same thing.
I was wondering whether the regen functions as a switch or a linear input? I am looking to use it to simulate engine breaking effect.
Re: Linear Regen
« Reply #1 on: January 14, 2019, 03:15:53 PM »
Hi Mike andto the forum.
Most of the GM controllers only have a basic On or Off switched operation for the regen.
To achieve variable regen, you would need to have a controller that is designed to support it, along with some form of brake lever (or thumb throttle) with a variable voltage output signal to control it.
As you will no longer require a clutch lever on your converted bike, perhaps this lever could be adapted to control the level of regen in conjunction with a controller that supports variable regen.
