Author Topic: Battery charger for Shark Pack 48V13.6AH  (Read 28434 times)
Offline Chris Morin
« on: November 06, 2018, 05:00:43 PM »
Hello everyone!
Here is my question; I would like to order a second charger for my Panasonic Shark Pack battery 48V13.6AH, but I don't know wich one? There only seems to be 24V and 36V charger for LiFePo4 battery on the site? Since I have a 48V Lithium battery, will the connector and power fit (excuse my english, i'm a french canadian!)? I would like to have the same 2 AMP Charger that I received with my battery, can someone tell me wich charger is compatible?
Thank you!
Christian
Re: Battery charger for Shark Pack 48V13.6AH
« Reply #1 on: November 06, 2018, 09:37:08 PM »
Hi Chris andto the forum.
As the Shark Pack does not use LiFePO4 cells, you will need a charger suitable for a 14S 18650 lithium pack with a regulated output voltage that matches the maximum charging voltage of your battery (presumably 58.8V).
I suggest that you contact Gary direct (Golden Motor Canada) by either email, phone or LiveChat, as he should be able to supply you with the correct charger.
