Author Topic: Magic Pie 5 Vector recuperation  (Read 23686 times)
Offline BreitiDE
« on: September 22, 2018, 04:20:37 PM »
hi, would it be possible to program or make changes so battery recuperation would be aktive if green Button is pressed. I do not like recuperation on normal drive, but often I like to recuperate if it goes downhill or I am save to break by recuperation ...
Re: Magic Pie 5 Vector recuperation
« Reply #1 on: September 22, 2018, 11:10:46 PM »
The regen function is combined with the power cutoff function which is activated by both the front and rear brakes.
The power cutoff function is a legal requirement on ebikes in many countries, so preventing it from working via the brake levers would probably make your bike illegal to use on public roads.
The green horn button could be rewired in parallel with the brake lever switches to allow the regen to work by simply holding the horn button depressed, but this would have to work in addition to the normal brake lever activation to keep your bike legal.
If you don't have a pedelec sensor fitted, I think it might be possible (and quite involved) to reconfigure the brake switch wiring to the throttle signal wire and cruise signal wire in conjunction with a 330 ohm resistor and a couple of diodes so that the brake switches simply cut the throttle signal going to the controller (and also disengage the cruise function if engaged) instead of activating the regen. This should still conform with the legal requirements of cutting the power with either brake lever.
The horn button could then be reconfigured to instantly operate the regen when pressed.
EDIT: Theoretical circuit diagram added
« Last Edit: September 24, 2018, 12:28:45 AM by Bikemad »
