Author Topic: Throttle stopped working on Magic Pie 4  (Read 33957 times)
Offline Thef0nz
« on: August 03, 2018, 06:13:27 PM »
The throttle stopped working on my Magic Pie 4 after climbing a big hill. No lights and no change in voltage on throttle signal wire. Looking for troubleshooting tips.
Re: Throttle stopped working on Magic Pie 4
« Reply #1 on: August 03, 2018, 11:49:41 PM »
The LED battery gauge on the throttle is fed directly from the battery and the gauge is completely independent of the throttle operation (although it does share a common ground connection).
If the Battery Gauge fails, the throttle should still operate normally, and vice versa.
Therefore, if the LEDs and the motor have both stopped working, it is probably a battery supply problem (poor wiring connection, keyswitch contacts, or possibly the battery's BMS).
As you haven't mentioned which battery you are using, you might want to check that your particular battery is capable of supplying at least 25~30 Amps of continuous current, which is typically lower than its maximum rated peak current.
What was the actual voltage reading that you observed on the throttle signal wire?
Offline Adamsavage79
« Reply #2 on: August 04, 2018, 02:56:41 AM »
Have you tried unplugging the battery from the kit, waiting a couple seconds and plugging it back in ?
