Author Topic: Battery Pack  (Read 23957 times)
Offline Adamsavage79
Battery Pack
« on: May 27, 2018, 04:19:18 AM »
I came across a China based website that, in my exp in the past with ordering from ships very quickly for China. What do you guys think ? I would have to buy another charger, or get an adaptor from Grin Tech to work with the Anderson Connector. It think it's a very odd design, that makes no sense. You need a Ground wire for the charger, yet the picture shows a dual Anderson Connector ??
Battery Pack: http://www.evassemble.com/index.php?main_page=product_info&cPath=1&products_id=178
Here are the replacement cells:  http://www.evassemble.com/index.php?main_page=product_info&products_id=175
Charger: http://www.evassemble.com/index.php?main_page=product_info&cPath=3&products_id=169
http://www.evassemble.com/index.php?main_page=product_info&cPath=3&products_id=170
Re: Battery Pack
« Reply #1 on: June 01, 2018, 10:11:28 AM »
If that battery uses those Headway cells it should be a good battery.
The two wire connection (Battery + and Battery -) is standard for most charging applications even though a three or four pin connector is sometimes used.
It should be possible to make up a simple adapter using a three pin socket to suit your charger's plug and then wire it to a couple of suitable Anderson connectors to match the Battery's charging connectors.
But I suggest that you check the output of your existing charger to ensure the output voltage does not exceed 58.4V or you may overload the new battery's BMS.
