Author Topic: Lamination thickness  (Read 26417 times)
Offline Jbwiden
« on: May 18, 2018, 05:00:23 PM »
I have been hearing that lamination thickness affects motor efficiency a and advertised as an advantage for other motors.
Does anyone know what the pies lamination thickness is. Mainly interested in the edge but knowing the others would be good too.
Offline Pwd
Re: Lamination thickness
« Reply #1 on: May 18, 2018, 07:29:52 PM »
I found this page. According to that, the lamination thickness is 0.45mm but I'm not sure if I trust that page yet...
https://www.goldenmotor.com/alison/magicpieedge/
Offline Jbwiden
« Reply #2 on: May 18, 2018, 10:46:38 PM »
Interesting page certainly looks like work in progress, though didn't see the mention of .45mm
« Reply #3 on: May 18, 2018, 11:53:37 PM »
Did you scroll far enough down the page?
0.45mm sounds pretty realistic to me.
Offline Jbwiden
« Reply #4 on: May 19, 2018, 12:31:02 AM »
Yeah went all the way but seems not all showed up on my mobile device.
Seems that this is thicker than many others are offering unfortunately. Though unsure of how large an effect.
Offline Jbwiden
« Reply #5 on: May 19, 2018, 06:55:06 AM »
Doing a little research it seems common thickness are 0.50mm and 0.35mm and some mentions of 0.47mm
0.35mm is considered the high quality option(higher efficiency and less cogging). Hopefully the 0.45mm is a mistake and it's actually 0.35mm, though I don't have any way to confirm.
Offline Jbwiden
« Reply #6 on: May 19, 2018, 07:02:55 AM »
And looks like confirmation that it's 0.35mm
>0.35mm Laminations for low rolling drag when pedaling unpowered.
https://www.goldenmotor.ca/products/Magic-Pie-Edge-%28VECTOR%29-700c-Rear-Conversion-Kit-%288%252d10-Cassette%29.html
https://www.goldenmotor.ca/products/Magic-Pie-Edge-%28VECTOR%29-26-Inch-Front-Conversion-Kit.html
> Strong torque: acheived by stronger magnets, thinner 0.35mm stacked lamination, innovative motor design, high capacity MOSFETs
(This was in reference to magic and Smart Pie but doubt it would not also apply to the edge)
https://www.goldenmotor.com/e-Bike-DIY/DIY-ebikekit.php
« Last Edit: May 19, 2018, 07:07:59 AM by Jbwiden »
