Author Topic: Throttle and Battery are Different Voltages  (Read 31440 times)
Offline Marlz
« on: April 10, 2018, 11:33:30 AM »
So I have a special situation and I want to try using a 24V battery on a MP5 with 48V throttle.
Possible?
Re: Throttle and Battery are Different Voltages
« Reply #1 on: April 10, 2018, 01:34:52 PM »
Yes this is certainly possible, but you will need to use a USB programming cable or Bluetooth dongle etc. to reprogram the controller's voltage setting to 24V and the throttle and motor will work fine.
However, the battery gauge on the throttle will not work, as none of the LEDs on the 48V throttle are likely to light up with a 24V battery.  ;)
