Author Topic: Magic Pie and Vector question  (Read 26508 times)
Offline Sohara
« on: April 04, 2018, 11:06:02 PM »
Can you tell me the shaft size of the Magic Pie 5 (VECTOR) 26 Inch Rear Conversion Kit and the Magic Pie Edge (VECTOR) 26 Inch Rear Conversion Kit (8-10 Cassette)
I currently have a have an 8 speed 11-34 cassette setup it looks like the shaft size is 3/8 or the metric equivalent
Just trying to decide which conversion kit is best. I know they make a freewheel  8 speed 11-34 but they are around 80 bucks
Sean
Re: Magic Pie and Vector question
« Reply #1 on: April 05, 2018, 12:11:51 AM »
Hi Sean,
All of the Magic Pies (including the freewheel version of the Magic Pie Edge) have a 14mm diameter axle with 10mm flats, but the cassette version of the Magic Pie Edge has a smaller 12mm diameter axle with the same 10mm flats.
All of these axles should fit into a standard 10mm (3/8") wide dropout slot.
80 bucks sounds a bit expensive for a 11-34T freewheel, I found one for less than $30 on Lunar Cycle's website.
Offline Sohara
« Reply #2 on: April 08, 2018, 04:08:33 PM »
Thanks Alan I will check lunar cycle
Offline Sohara
« Reply #3 on: April 08, 2018, 05:16:07 PM »
 I am thinking of going with the 8-speed freewheel version of the edge due to the larger 14 mm shaft. I measured the rear wheel space at 137 mm Will I have to spread the frame to get it to fit? it is an aluminum frame
