Author Topic: VEC300/72V STALL PROBLEM  (Read 24983 times)
Offline Yash
« on: March 30, 2018, 09:32:02 AM »
 Hello,
I am using another motor to run with VEC300/72V and I am having motor stalling problem i.e. when I twist the throttle  led blinked 4times.
My PMSM motor specs are:
8pole
12 stator wdg
1000rpm max
72 volts
Hall are arranged 120edeg
Hall sensor : Honeywell ss41
100Amp peak
60Amp Rated
I have not attached temp sensor yet.
Note : The last file used for programming is attached.
