Author Topic: Replacing MP5 controller  (Read 28469 times)
Offline Socalbiker
« on: March 25, 2018, 12:21:42 AM »
I still get battery voltage but no longer get 5V from my controller, so I'm pretty sure the controller is shot after ~6000 miles.
 I've taken the philips screws in the attached picture out but can't get the controller out. Based on pictures from other posts or the new controllers @GM Canada I think the part with machined words Golden Motor Patented should just lift out. I've tried to gently pry it out but don't budge.How do I get it out?
Re: Replacing MP5 controller
« Reply #1 on: March 25, 2018, 10:03:52 PM »
The controller is usually sealed around the flange with silicone sealant which can sometimes make it difficult to separate.
Make sure that you also remove the clip holding the cable to the axle:
You should then be able to free the controller from the housing by inserting a knife or flat screwdriver blade into the joint between the Controller heatsink cover and the controller housing:
Check out Gary's video to see how the controller should come out.
Offline Tommycat
« Reply #2 on: March 25, 2018, 10:28:55 PM »
This video also by Gary shows more of what it takes to remove a controller...all tho this is a Magic Pie 3.   ;)
Controller Removal
WOW 6000 miles!
T.C.
Offline Socalbiker
« Reply #3 on: March 26, 2018, 03:07:59 AM »
Thank you Alan and TC for all the info
Offline Socalbiker
« Reply #4 on: March 28, 2018, 04:12:03 PM »
Does anybody know if these screws are m12?
« Reply #5 on: March 28, 2018, 08:14:00 PM »
M12 refers to the outer diameter of the threaded section in mm.
I would expect the thread to be either M5 or M6 but definitely not M12.  ;)
Check out this datasheet for more information on thread sizes on countersunk headed screws.
Offline Tommycat
« Reply #6 on: March 28, 2018, 10:49:58 PM »
Taking one from my Magic Pie 5 purchased in October of last year, the specs are as follows...
On the head is stamped:        SCR      10.9
In reference to Alan's chart.
s or Hex head size would be -------------3mm
d or thread diameter is-------------------5mm
l or total length is-------------------------16mm
...soooo   M5.
I don't have a thread comb for the pitch...
It seems to me that they are like this type...HERE.
You will need to verify the thread pitch. They are suppose to be corrosion resistant, tho the one I took off has rust on it!   ::) Recommend anti-seize on re-install.
Get that controller out yet?   ???
Regards,
T.C.
Offline Socalbiker
« Reply #7 on: April 02, 2018, 03:06:32 PM »
thanks for all the help. traveling so now work on bike for now
