Author Topic: VEC500/96Vdc does not turn on.  (Read 26675 times)
Offline EACV
« on: March 15, 2018, 09:46:15 PM »
My VEC500/95Vdc appears to have a small burn on one side of its board and it won't turn on, I have pictures that could maybe better help adress this situation. Any help is greatly appreciated.
Re: VEC500/96Vdc does not turn on.
« Reply #1 on: March 15, 2018, 11:57:44 PM »
If the controller is still under warranty, you will need to contact your supplier, but if the warranty has expired, it might be worth asking GM China if they are able to offer a repair service (sales@goldenmotor.com).
Posting pictures might enable someone with the same controller to identify the failed component, but I suspect there may be further damage that may have caused (or have been damaged by) the visible failure.
