Author Topic: Magic Pie 5 troubleshooting help  (Read 33194 times)
Offline Socalbiker
« on: March 15, 2018, 06:21:07 AM »
Had to fix a flat. When I got bike back together there was no throttle response. What I have tried to isolate problem:
- CA shows I have correct voltage
- all the LED's on throttle light up.
- tried a different throttle
- tried a different harness
- tried the troubleshooting tips - twist throttle 4 times also hold cruise control button on
I'm pretty sure it's something in hub or controller. Any suggestions on how to figure out where the problem is?
Offline Tommycat
Re: Magic Pie 5 troubleshooting help
« Reply #1 on: March 18, 2018, 02:33:05 PM »
The throttle has 3 wires going to it for motor control. Some how the controller is not seeing a 1 to 4.25 voltage reading on the throttle signal wire. Things I would check... Bent or broken pins? Is the controller putting out ~5 volts to the throttle? Is any thing trying to make it back? Good throttle ground wire?
With your previous trouble shooting I would probably start checking for voltages at the disconnected 10 pin connector...
Here's a couple maps.
Just a word of caution...be wary of that motor spooling up!
Regards,
T.C.
Offline Socalbiker
« Reply #2 on: March 19, 2018, 03:27:04 AM »
Thanks TC.
I am pretty sure the voltage is making it to the throttle since all the LED's light up when I energize the system,  if I unplug the 10 pin connector the LED's on throttle go dark. I need to get a small bus wire or wire clip that I can use with a multi-meter to probe the pins.
The other thing I've tried is checking with the vector control software, but it no longer connects. So for now I suspect it is the controller.
Offline Tommycat
« Reply #3 on: March 19, 2018, 02:15:55 PM »
Actually the throttle gets two different voltages...Full battery voltage that is provided for the LED display charge status. And regulated 5 volt supply for the throttle operation... they both use the same ground.
Yes, it's really tight in there and you absolutely don't want to be shorting the wrong pins!  :o  Double check the map, and note which side the labeling is for...PIN or Receiving side.
Yes, It also uses the same 5 volt power source. But I'm still holding out hope that it is just a bad wire or two BETWEEN the plug and controller!   :)
Regards,
T.C
Offline Socalbiker
« Reply #4 on: March 24, 2018, 11:13:45 PM »
Looks like it's the controller, I get the battery volt, but no 5 VDC on throttle or control harness connector.
Offline Tommycat
« Reply #5 on: March 25, 2018, 11:25:55 PM »
Once you get it out... :o  perhaps you'll want to check the white wire for continuity... If this picture for the Magic Pie 4 holds true for the 5...
Or look for the SP+ board connection point. Or even check for the 5 volts at the board.   ;)
T.C.
