Author Topic: Is it possible to fit a sprocket to a Magic Pie III front wheel?  (Read 22352 times)
Offline Geoffgeoff
Hey just joined forum was wondering about attaching a sprocket to a front hub motor, I have a Magic Pie 3 cast hub 20inch I think ? :)
Re: Is it possible to fit a sprocket to a Magic Pie III front wheel?
« Reply #1 on: July 10, 2017, 06:31:18 PM »
Hi Geoff andto the forum,
The axle and the right hand side covers are different on the front and rear Magic Pies and would both need to be changed to enable the conventional threaded freewheel to fit:
The main cast section of the wheel would also need to be reversed in relation to the stator and axle assembly so that the offset rim would be more central within the rear dropouts.
Check out this post for further information regarding the offset of the rim.
