Author Topic: Is bluetooth built into the Edge motor or do you need the bluetooth plug?  (Read 23447 times)
Offline Steveohlhaber
Is bluetooth built into the Edge and Pie motors or do you need the Bluetooth cable thing to use the app?  I see in the older videos that you are using a Bluetooth plug.
The Bluetooth is only available by using the plug in Bluetooth dongle, which means that you cannot use both Bluetooth and the LCD Smart Display unit at the same time.  :(
