Author Topic: MP5 cruise control and horn wires  (Read 27613 times)
Offline Vanarebane
« on: May 06, 2017, 09:54:00 AM »
Hello!
My bicycle began to fall and I accidentally grabbed the cord and pulled them apart.
Now I don't know which wire goes where. How should the wires be connected?
Wires can be seen here.
Thanks in advance!
Re: MP5 cruise control and horn wires
« Reply #1 on: May 06, 2017, 12:52:57 PM »
Hi Vanarebane,
The red and black wires are slightly longer as they have to go to the red cruise control button switch, and the shorter yellow and orange wires go to the green horn button switch.
The switches are identical so it doesn't matter which one you use for each function, and the polarity of the switches is unimportant, so the two wires can connect to either of the switch terminals.
I have attached a picture showing the inside of one of my more recent switches which should be the same as yours.
« Last Edit: May 06, 2017, 01:16:24 PM by Bikemad »
Offline Vanarebane
Re: MP5 cruise cotrol and horn wires
« Reply #2 on: May 06, 2017, 12:55:22 PM »
Thanks a lot!  :)
