Author Topic: Battery Charging While Riding  (Read 23039 times)
Offline OldManTomahawk
« on: April 11, 2017, 08:11:06 PM »
I seem to remember seeing, somewhere, that when you are coasting (say going down hill) that the battery is being charged.  I also think I remember that you had to be braking.  Is this correct or does it just charge when power is not being applied?  (Magic Pie Edge) Thanks, tom
« Last Edit: April 11, 2017, 08:15:00 PM by OldManTomahawk »
Offline Pwd
Re: Battery Charging While Riding
« Reply #1 on: April 13, 2017, 08:27:37 PM »
I think you are referring to regenerative braking. It will only charge when the brake is applied and if the battery is below the high voltage cutoff to prevent overcharging.
« Reply #2 on: April 13, 2017, 10:37:22 PM »
Can I assume that only one of the brake levers need be used and with very little braking pressure applied.  I just want the regenerative option to increase riding range.  Thanks, Tom
Offline NR
« Reply #3 on: April 14, 2017, 04:12:29 AM »
As I understand both brake switches are connected together so any brake or external connected brake-switch will work as regen. Applied brakeforce can be set in software  ;)
