Author Topic: 3KW BLDC Golden Motor stalling with Jeti Spin Controller  (Read 26070 times)
Offline Justin824
« on: March 31, 2017, 08:25:36 PM »
Hi, I'm a new user hoping someone on this forum can help me.
I'm using a 3KW BLDC Golden motor with a JETI Spin Pro 200 Opto motor controller.
https://www.goldenmotor.com/frame-bldcmotor.htm
http://www.jetimodel.com/en/katalog/Speed-Controllers/@produkt/SPIN-Pro-200-opto/
The motor spins up ok, but when I apply even a little bit of load to it, it stalls.
The motor is not drawing excessive current and the voltage to the controller does not dip significantly. I think the problem is likely my motor controller configuration. Does anyone know how many polls this motor has, and what its frequency and timing specs should be?
Any other suggestions or advice for how to fix this problem would be appreciated!
« Last Edit: April 03, 2017, 02:31:36 PM by Justin824 »
Re: 3KW BLDC Golden Motor stalling with Jeti Spin Controller
« Reply #1 on: March 31, 2017, 11:27:43 PM »
Hi Justin andto the forum.
I'm pretty sure that the 3kW motor has 8 poles (4 pole pairs) just like the 5kW motor:
Unfortunately I have no idea what its frequency and timing specs should be.
« Last Edit: July 04, 2017, 09:02:46 PM by Bikemad »
Offline Justin824
« Reply #2 on: April 03, 2017, 02:30:06 PM »
Thank you! That's a start.
Offline Justin824
« Reply #3 on: April 03, 2017, 02:45:41 PM »
After setting my controller to 8 poles, the motor still stalls under any load. It will run under no load, though. Any suggestions would be appreciated!
